I have a 2004 TJ. It was dying when I stop accelerating. I got some sea foam to try, when I went to start it (been 5 days) it does absolutely nothing. The only thing I have done in those 5 days is remove a RightTrack module for insurance. Any suggestions?
Do you have electricals working?
No, nothing at all
First things first, check your battery and alternator.
Yeah. Check battery and alternator power. Maybe re-charge or replace battery.
My 00' TJ also started dying immediately after I stop accelerating when driving, and had weak idle. It came to be the IAC valve that was dirty. I cleaned it up and idle got slightly better and no-dying anymore. On the way, i cleaned all the air intake system, bought new air filter and will change battery soon as well (because it is getting powerless).
Good luck
