1 - 10 of 10 Posts
Ok so I went to start my Jeep and it died 3 times, finally I took off and it was fine.. I didn't think another thing about it, today we drove into town stopped by a friends house, went to leave and it did the same thing.. It was acting like it wanted to start but wouldn't. I gave it gas and it didn't help :(
I was thinking maybe the distributor module? I'm not really sure, any advice?
Well I tried that.. It is like a hesitation it started and then would die before I could do anything else?
I'd start with tune-up, fuel filter if it hasn't been done. check fuel rail presure,spark. may clean the throtle body, IAC. see if that helps.
Discussion Starter #9
I checked the codes ( a 12 and a 55 ).. It is in need for a tune up, So I will try that!!! Thanks!!!
Discussion Starter #10
Thanks the fuel filter was so bad, it started and ran fine the first time I tried after changing the filter... I even did it myself! :D
1 - 10 of 10 Posts
