I've had everything done rebuild trans, new. Slave and master, new clutch and lines, everything under the sun, and it still grinds,help me going crazy
More info please.
When does it grind. Please explain all of the symptoms. It grinds, is very vague.
My guess from this is you need to bleed the slave more. Try pressing the clutch pedal two or three times then hold and shift the gear, see what happens.
It doesn't grind in park it's fine then, when the jeep is moving shifting gears. It grinds in 1 st threw 4 I don't drive it hard nice and easy, sometimes it gets stuck in 2nd have to press the clutch and add gas sometimes then here a loud clunk, I'm lost.synchronizers have been done bearings and everything in the trans, new salve and master , new clutch and fly wheel , I've bled the clutch and slave multiple times, the clutch is good, I'm lost my mechanic is great and he is even lost.help anyone.
Judging by the transmission noises and how it sticks in second, I'd have a talk with the guy who rebuilt it. That's transmission problems.
