So I just installed a set of Teraflex Swaybar disconnects and in the package with the clips was a set of these sleeves/bushings
They are not mentioned in the inventory list and there is no mention in the instructions...
So what the heck are they for?
Oh... and no stickers? What's that all about?
I too had them in mine, only consensus I could think of was for use with the stock bolts through the bottom instead of the pins.
No, the outside diameter of the pin and the bushings/sleeves are nearly the same.
They are used for stock bolts as others have stated. Sleeves come with the kit in case you have a Rubicon with electronic disconnect. In that case you wouldn't use the new quick connect pins since you disconnect at the power motor. you would install the sleeves on the lower end of the link and used stock hardware.
I was wondering why in the world you would bolt on your quick disconnect sway bar links.
It didn't even register that Rubicon owners would use them as just replacement links.
That makes sense now. Thank you.
