1 - 20 of 27 Posts
Commercial Member
Last year I installed a Harbor Freight 12,000 winch inside my wife's stock front bumper. I got a $299 coupon for a 12,000lb winch In the mail the other day so I decided it was my turn for a winch.
Here is the winch installed upside down:
Here is the plastic stock bumper cut and mounted (yes I have to clean it).
Completely hidden
This is where I put the control box and vacuum pump
Awesome job! What did you use for a winch plate?
Commercial Member
Discussion Starter · #11 ·
That looks amazing, good work! The silver cover, is it easy removal to use the winch?
The silver cover usually is held on by 8 screws, top and bottom edges. I have it held on by only two screws now, where the dealer drilled holes for the license plate. If I go wheeling I would take the cover off ahead of time.
KBoB Very nice work! Looks like you flipped the mounting plate upside down? What was involved in moving the steering pump?
The winch doesn't care if it is upside down or not, and it has no effect on its reliability. The steering pump was not moved, the vacuum pump was. I used the Or-fab kit to relocate the pump.
Neral22 Very nice. How much would you charge me to install mine
It's a lot of work, it took me a day and a half.
slapmypc Very slick! Will the winch operate reliably upside-down?
And How did you modify your bumper into a mid-stubby? very cool!
I used VDP stubby end caps, it was super easy.
dcaprio Awesome job! What did you use for a winch plate?
I used the universal plate from harbor freight ($40). The front and rear lip had to be trimmed, but that was a quick job.
JeepChad Could you post the steps to do this? Or at least some pointers or things you learned from this? I've been planning on doing something similar.
There is a write up somewhere, I'll see if I can find you the link
Very nice. I rather like it exposed, but that's a personal preference. You could probably put the plastic cover on with Velcro if you wanted. I have my motorcycle tag on with Velcro with no issues. I moved it closer to the tail light and had to be able to get to the seat lock. Your cover has the wind pushing it on, so it would be even more secure for you.
Commercial Member
Discussion Starter · #14 ·
excellent - this seems very cost effective, too. just under $400?
Winch- $299 (sale price)
Winch plate- $40
12' jumper cables (6 gauge) used to extend the winch control box- $17
So $357 plus tax
And for another $30 you can but a wireless winch remote
Great job, been doing some research and looking for stock bumper and winch threads.
How much would you estimate the winch/plate/fairlead weighs? I'd really like to do that but I have the lightest front springs (13s) and a spacer leveling kit, I'd like to hang some weights on the front and see how much it will drop.
Commercial Member
Discussion Starter · #17 ·
According to google the winch is 88lbs, so maybe another 10 for the plate
Commercial Member
Discussion Starter · #18 ·
Are there any space limitations when it came to installing the winch? Or will most any winch fit?
The space is tight and several areas need to be modified to make it fit (mostly the inner metal bumper). I'm not sure about other winches.
Thanks, the plate is lighter than I thought. Have to stop by Harbor Freight and check them out.
1 - 20 of 27 Posts
