1 - 10 of 10 Posts
Does anybody know how to keep the fog lights on when you turn the high beams on? Is there a wiring kit or anything out there to fix this?
I bought my bumper with fogs as the one mine came with didnt have them. I wired them to a switch. You could do this fairly easily, only downfall is your steering stock to turn on/off the fogs wouldnt do anything.
I did this on my 03 Mustang. I simply pulled out the relay, then figured out which terminals turned the fogs on with my parking lights. I made a jumper wire and connected the 2 terminals. Now my fogs are on when I turn on my parking lights,(and turn on factory fog switch) and stay on with both high and low beams. I'm sure something similar would work on my JK. I may have to look into it tomorrow. If I figure anything out, I'll post it up.
Much appreciated if you do figure it out
Well I couldn't figure out the wiring like I did in my Mustang. But after downloading and update for my BullyDog tuner, I found a nice little feature in the options. This feature allows you to keep your fog lights on with brights. I'll get some pics in a bit.
Here is a shot with the fogs and low beams. I have the Truklite LEDs so you can see only the top half is lit(low beam)
and here it is with High beams and fogs. Both top and bottom on light are lit.
1 - 10 of 10 Posts
