1 - 12 of 12 Posts
Any experience with 255lph fuel pump brands that work in a TJ tank? I’m looking at walbro, aem, quantum, etc. First hand experience would be awesome. Thanks!
Stock volume output adequate for stock setup
Kind of unique for TJ as regulator also in tank and no return line from rail
Does it have a rail return line to trunk to deal with increased volume output not consumed by engine?
I’m using the same in-tank return system, just looking to replace the pump with a higher volume.
Knows a couple things...
There is no return system on the TJ. The OE fuel pump is more than capable of providing enough fuel for your V8.
Omg. Let me try this again.
Does anyone have experience with a high volume fuel pump using the stock tj returnless system (other than the in-tank pressure regulator)?
I guess he wants high in tank volume circulation for churning of fuel in tank
Otherwise don’t see the advantage as wont keep rail cooler as ain’t circulating thru the rail
Wow. Alot of assumptions here. You don’t know what my build plan is, and I’m not asking if a high volume pump is required for it. I just wanted to know if anyone had experiences with the different high volume pump brands.
might be a few here that could give you info , but this'd be better posted on pirate 4x4 then you can draw from a wide variety of custom fuel setup users.
Like I said higher volume flow will just add extra fuel churn in tank and increase the current draw on the circuit to the fuel pump
1 - 12 of 12 Posts
