I'm trying to source springs of a higher than stock rate without raising the vehicle height beyond stock, or at least a negligible amount if any.
Has anyone come across some quality springs that fit those parameters?
Thank you kindly.
Thank you kindly.
H&R springs have a stiff rate that effectively only gives an extra inch of height over stock........basically negligible. If your loadin your rig up with a lot of weight they will work well.
I ran H&R' on a track BMW 2002 back in the early 90's and loved them. I'll have to look into the rates for the TJ, thank you very much for your input.
