1 - 1 of 1 Posts
I'm having a starvation, hitting a "rev limiter" issue at 3500 in 3rd. 2nd gear has it to a much lesser degree but 3rd Won't pass thru it to rev higher.
I removed the whole AIr cleaner assembly as a troubleshooting step and the trouble completely clears up and I have a lot more power and will pull all the way to 4500
The filter is new and clean and the snokel flaps are working and open. Any chance this is more than a simple air flow restriction in the snorkel somewhere? Have I reached the flow limit of the air cleaner assembly? Could it be some antiquated WOT sensor in the AC that's causing it?
1 - 1 of 1 Posts
