:wavey:Hi Guys, Here we go.Replaced all vac lines, full tune up, wires pluggs, filter, cap ect...Before I start replacing sensors or related parts, here are symtoms Doesn't want to run while cold will slowly loose rpm's until it "chuggs off".Manually keep it running with gas pedal keeping revs up till lts warm it idles ok.Once warm if I give it more than just a little throttle at a time it almost dies then rpm's will slowly pick up.If I give it to much throttle it sometimes will blow back thru the throttle body, before rpm's rev up.Specs: 1989 2.5L TBI 5 speed.I dont have the budget to start throwing parts at it till it is straightened out. I do Thank all of you for your continued help.Keep waving!!!:wavey:
