1 - 10 of 10 Posts
Hello all - I installed my DIY posi lok per a popular write up here on the forum after discovering some missing sections of vacuum line near the actuator. Though I have had it successfully engage multiple times, I'm finding it more and more difficult to pull the handle, to the point I can't get 4WD to engage at all now. I've checked to ensure that the cable isn't locked, had it all apart 3 times to ensure there's no binding anywhere (fork action via lever seems fine when disassembled and off the collar)....am I missing something? A little disappointed after arriving at our wheeling destination last weekend only to find I was not going to get 4WD to engage. Thanks in advance.
I bought the posi-lok kit and mine acted the same way. smooth as butter when I first got it and increasingly harder as it aged. found out mine was the cable was close enough to the motor that the heat dried out the lube. So I had to dismantle the cable and used a dry graphite powder to lube it. Got it from a Honda motorcycle shop, they use it for clutch cables. Back to working great again, until I got tired of all the bullshit of have to engage the t-case, then getting the cable to engage the front end.
Went to the TJ solid axles in the front. Comes with the larger u-joints and no worries if its in 4wd or not.
It makes a big difference. And the heat wont affect it.
When I unhooked my cable it moved freely before I used the graphite lube, so I didn't think that was it. After I lubed it with the graphite I could hold the housing and the cable would fall through. Silky smooth operation.
I did the DIY route with a locking cable from Napa auto, I could not route the cable in achy that wouldn't make it bind up. I could get it to engage, but it felt like I was going to rip the damn handle off the cable. I had it installed for about 3 days, then I ripped it out and put 1 PC shafts in with the " larger" ujoint and modded them to take a full circle c clip.
I recommends that you change the fork. May try that. I'm getting one for mine soon and I have to change the one on mine ,as directions recommendations. Lots more reliable that vacuum. Good and simple upgrade.
until I got tired of all the bullshit of have to engage the t-case, then getting the cable to engage the front end. Went to the TJ solid axles in the front. Comes with the larger u-joints and no worries if its in 4wd or not.
I don't want to hi-jack this thread but could you give the pros and cons of switching to the TJ solid axles. I have the posi lock cable kit but if the axle swap a better option will leave it sealed in the box. Thanks
Pros: no wondering if it's engaged
Larger ujoints
More likely to find a spare on the trail
Cons: driveshaft will spin at all times
Have to add a seal at the diff
The cons arent really cons in my opinion. Grind the new ears to clerance them for full circle c clips and your set. If donor TJ's are hard to come by, you can also use xj shafts, but make sure you look for the bigger ujoints.
Hijack off!
If changing axles is not possible now, you can slide the fork over and keep it engaged full time.
1 - 10 of 10 Posts
