Just a side note on rust where holes are drilled. One way to prevent rust from forming on holes that you drill is to use clear fingernail polish. Clean the area right after you drill the hole, paint it with the polish. Works good on rock chips also.The bug deflector will cause rust where the holes are drilled.
