Today I noticed my 95 yj's hose in the bottom middle of my dash is broken can someone please tell me what it's for. Thanks.
Pics or a little more info would help. What type of hose, or size? The only hose I know of in the middle of the dash is the defrost tube. Looks kind of like a clothes dryer vent hose but smaller.
I think that's it it's in the bottom middle. I thought it might have had something to do with my 4x4 light not coming on.
It should run from the heater housing assembly up to the dash vent. As far as your 4wd light........ I have an 87 that I've had about a year now and the light never has worked. I have checked the bulb, the connections, and the wiring and all I can figure out is that its the vacuum operated switch located below the battery tray. The only place to get it is at the dealer, so I gave up. Never even checked on a price for it.
Thanks for your help I believe that is the hose and I think I'll check some of that out about the 4wd light. But what will it do if the hose is broken? Will the defrost just not work?
You may still get some heat to the windshield, but not as much as you should.
