1 - 9 of 9 Posts
Good evening,
My 2014 automatic Jeep Wrangler is having issues. Around New Years I had the hot alarm come up. Added oil and problem went away , had an oil change after that and even went on a long trip and no issues. Now , a few weeks ago, had the same issue , but I had recently had an oil change on it. Read around and found out that it may be low on tranny oil. It was a little bit low , the fluid itself looked pristine. I added some and again , the problem was solved. I had not moved the Jeep much due to the Covid -19 problem.Been off work for a few days. This morning I went to turn it on and it hard a very hard start. Drove it and all of the sudden , that same alarm , only this time as soon as I turned it off, it won’t start. I had it off for a few hours. Just a few minutes ago , I went outside , It’s Pretty cold. I tried to start it, which it did, but went off right away. However I noticed the Trans temp was at 180. How is that possible if it’s been off for hours in a pretty cool temperature. Can some one give me some advice, it’s literally my only vehicle. What should I do from here? View attachment 4418422
It sounds like there may be a problem with the torque converter staying locked up which can generate heat and make starting hard.
Did the trans temp give the reading in park or drive.
If park, the evic will display engine temp and not trans temp.
when mine started doing this, I wound up replacing the transmission, if you start to get the torque converter error your tranny is likely on it's last leg.
While in park , the tranny temp said 176. Now all the alarms on the dashboard have lit up and the Jeep won’t even start.
1 - 9 of 9 Posts
