Hi all,
I know there has been discussion about this in the past. I have a 2011 JKU with 126,000 miles on it and I am getting a hot oil read out on my dash occasionally when driving more than 30 minutes on the freeway. I’ve seen people say that there is an aftermarket cooler to install, and a sensor that it could be as well. Has anyone purchased either of these and know part #’s? And while I’m here, does anyone know the part # for the front driver blinker/running light assy that the bulb slides into?
thank you in advance!
RETIRED MODERATOR
It's worth also asking if you've recently/ever changed the transmission fluid in your Jeep. Older ATF will not do you any favors here.
Discussion Starter #7
Hi, No, I have not ever changed it. But after your question, it’s also going to get done.
