So the jeep has been having trouble starting lately. On a warmer day, if I shut it off then go to turn it over 5 or so minutes later, it'll almost lag a little bit and seem like it's going to die but then it fires over. I've read about the TSB for the 00-04 tj's but I have the 97 4.0 in my tj.
I know I have a leaking drainback valve in my fuel pump as well, but I don't think that would do it? Unless the lack of pressure in the system is causing a vapor lock in my fuel rail?
I don't have problems with it while it's running, just when it starts hot.
I plan to clean the injectors and replace the plugs/wires/cap/rotor with my next oil change in about 1000 miles, do you think it could be related to this and I should do that now? Or does anyone have an idea of what this could be?
Anyone?
Why not just try the insulator sleeve to see if it really is vapor lock? It's looks to be a simple repair but I suspect you will need a new fuel pump/regulator unit. You should check the fuel pressure next time you have the starting issues.(approx 49psi)
Could the insulator sleeve fix this issue though? I'm not getting any codes, and I don't have the same symptoms others have where it runs rough for a minute or two.. I know my check valve is bad it's one project that's on the list.
