It will be...even more sluggish. I would definitely regear before you put the tires on.
^^^You are not going to like it......:nonono:I've joked on here that I wanted 35's but its finally happening. I've placed my order with DT and the 15 inch level 8 wrapped with 35 inch MTR's will be here next week.
I got what I wanted... yay.
Now for the reality of the situation. I've already looked on the chart and already see that my current setup is less than ideal for 35's. As it stands, I'm at 4.10 pushed by the 3.8. How bad is it going to be considering this thing is already stupid sluggish? Currently, I have what look like to be 32 inch tires, maybe just under.
I think that info makes a big difference, there are many people running 35's with worse gears that aren't too bothered by its performance.Technically speaking, its more of a Mall Crawler as I'm in Houston and trails a very limited. It is my DD. 07 Sahara Unlimited Auto.
I already know its going to be sluggish, I'm just wondering if its going to be unbearable until I re-gear. It sees very little highway.
Did Sahara's ever come with 4.10 gears? Are sure it's not 3.21, sounds that way to me. A 3.8 with 4.10 gears should be pretty snappy with only 32" tires.It is my DD. 07 Sahara Unlimited Auto.
4.10 is according to the build sheet however calling around to diffract shops today for regear quotes reinforced my suspicions that I may indeed have something much higher.Did Sahara's ever come with 4.10 gears? Are sure it's not 3.21, sounds that way to me. A 3.8 with 4.10 gears should be pretty snappy with only 32" tires.
Yes some early sahara models came with 4.10 gears, I think they were part of the tow package.Did Sahara's ever come with 4.10 gears? Are sure it's not 3.21, sounds that way to me. A 3.8 with 4.10 gears should be pretty snappy with only 32" tires.
In what gear for manual would you see those rpms? My guess would be 4th correct? Don't think the chart says.Looks like with the auto you're at the very edge of "acceptable". With the Manual, it's a bit better. Save the regear money, stack the tires in your garage and trade it in on 2015![]()
Does anyone have that chart for the 3.6 auto?
