Assuming I have a system that consists of a 60w RMS per channel amp driving 4 5.25 coax speakers, and that I'm not looking to blow anyone off the road with volume...
I want to mount one or two subwoofers in the front panel of a tuffy cargo box (the side facing the back of the front seats).
Can anyone make any recommendations on size/number of subs, and an appropriate amp to drive them?
The box itself is steel, 3ft wide, 16" tall, and 2ft deep. The plan would be to essentially build a sealed enclosure out of MDF, and secure that inside the Tuffy box (with appropriate hole(s) cut to match.
Here's a stock photo pic -
Off hand, I would say a 250-300wattRMS amp, to power 2-10" subs, which will allow about 150wattRMS per sub. The power rating I decided on is based on a ratio of my Alpine PDX-V9 which gives 100wattspeakers/500watts sub. Alpine actually sells a perfect single 5/channel amp for 60wattRMS Speakers. It's the MRX-V70.
Alpine Electronics of America, Inc.
Or, the Alpine MRV-M500, is a 4ohm 300wattRMS mono channel amp.
Alpine MRV-M500 Mono subwoofer amplifier — 500 watts RMS x 1 at 2 ohms at Crutchfield.com
For a smaller amp you might try the JL with the same 300watts of power.
JL or Alpine are probably your top choice of amps.
JL Audio JX500/1D Mono subwoofer amplifier — 500 watts RMS x 1 at 2 ohms at Crutchfield.com
