1 - 20 of 30 Posts
I"m trying to determine if my JK has been lifted or if its factory. How can you tell. I see Jeeps on the road that look lower than mine but mine doesn't seem to be that high. What do I look for?
.... What do I look for?
Ummm, a lift....
Anything not OE. Springs without white tags, different shocks, relocation brackets, adjustable arms, etc etc etc
Look for spacers, or plastic discs, on top of the springs.
From the pic, it looks like you have some lift. Park it next to a stock jeep and take a pic.
Red shocks? Only Rubicon and Willy's have them if I'm not mistaken. Perhaps someone slapped Rubi suspension on it?
That would lift it over a regular Sport.
It was also a option on the sport as well, at least here in Canada. I think the option was listed as Heavy Duty Off-Road Suspension Package or something along those lines.
Nworker: You could try and get the build sheet, would say on there if you had something like that.
Mine had a little 2" spacer lift on it when I got it (used). I wouldn't have known if a 4x4 shop guy hadn't crawled under and looked at it. That little spacer lift caused problems with steering that took an adjustable track bar to fix.
Grumpy Old Guy
Take a picture from the side. You cant tell at an angle.
Discussion Starter · #11 ·
Vehicle Description 2012 JEEP WRANGLER SPORT 4X4
STANDARD EQUIPMENT
Monotone Paint
160 Amp Alternator
600 Amp Maintenance Free Battery
Electronic Stability Control
Hill Start Assist
4-Wheel Disc Brakes
Low Back Bucket Seats
Easy Access Passenger Seat
Reclining Front Seats
Rear Folding Seat
RR Head Restraints Outboard Seating
Advanced Multistage Front Air Bags
Front Seat Area Carpet
Cargo Compartment Floor Mat
Cargo Tie Down Loops
Front Floor Mats
Sport Bar w/Full Padding
Full Length Floor Console
Rear Compartment Covered Storage
Storage Tray
Command-Trac Shift-on-the-Fly 4WD
Next Gen. Dana 30 Solid Front Axle
3.21 Rear Axle Ratio
Next Gen. Dana 44 HD Rear Axle
Conventional Differential Frt Axle
Conventional Differential Rear Axle
Tinted Windshield Glass
Front Door Tinted Glass
Full Metal Doors w/Roll-up Windows
Rear View Day/Night Mirror
Sliding Sun Visors w/Mirrors
Manual Mirrors, Fold-Away
Sentry Key Theft Deterrent System
Premium Instrument Cluster w/Tach
100 MPH Primary Speedometer
Manual Door Locks
Temperature & Compass Gauge
Manual Windows
Var Intermittent Windshield Wipers
Single Low Note Horn
12V Auxiliary Power Outlet
Glove Box
Tire Pressure Monitoring Warning LP
Front Passenger Seat Belt Alert
Front Dome w/On/Off Switch Lamp
Halogen Headlamps
Front Fog Lamps
CHMSL Lamp
Black Front Bumper
Black Rear Bumper
Black Front Frame Overlay
Body Color Grille
Wrangler Badge
Trail Rated Badge
Accent Color Fender Flares
Jeep Badge
Sport Badge
Black Sunrider Soft Top
18.6 Gallon Fuel Tank
Speed Control
Gecko Pearl Coat
8 Speakers
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
Radio 130
Power Steering
Normal Duty Suspension
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Outside Tire Carrier
P225/75R16 BSW On/Off Road Tires
16X7.0 Lux Styled Steel Wheels
Fuel Tank Skid Plate Shield
Transfer Case Skid Plate Shield
2 Front & 1 Rear Tow Hooks
Tethered Fuel Filler Cap
Non Locking Fuel Filler Cap
English/USA Language
Protective Coating and Remover
Base Interior Accents
Seat Parts Module
Instrument Panel Parts Module
Front End Parts Module
Complete Chassis Parts Module
Tire & Wheel Parts Module
Complete Body in White Parts Module
Complete Painted Body Module
Build To U.S. Mkt. Specifications
GVW Rating
U.S. Dealer Retail
Zone 66-Orlando
JK/5402 Vehicle Family
Four Wheel Drive (4WD)/(4X4)
Price Class L
Left Hand Drive (LHD)
2012 Vehicle Specifications
Two Door
Short Wheel Base (SWB)
Vehicle Order Tracking
U.S. Specifications Label
North Carolina Ship to State Code
Carb. Code 04
Smog Code 06
North Carolina Sold to State Code
OPTIONAL EQUIPMENT
Cloth Seats w/Adj. Head Restraints
Black
Connectivity Group
Hill Descent Control
Traction Control
Electronic Roll Mitigation
Hydraulic Assist Brake Booster
Driver Height Adjuster Seat
Rear Seat/Wheelhouse/Cargo Carpet
Front Seat Back Map Pockets
Chrome/Leather Wrapped Shift Knob
All Automatic Transmissions
5-Speed Auto W5A580 Transmission
3.6L V6 24V VVT Engine
Sunrider Soft Top
Air Conditioning
Vehicle Information Center
50 State Emissions
Engine Oil Cooler
Gecko Pearl Coat
SIRIUS Satellite Radio
Uconnect Voice Command w/Bluetooth
Audio Jack Input for Mobile Devices
Remote USB Port
Leather Wrapped Steering Wheel
Goodyear Brand Tires
Matching Spare Wheel
All Steel Wheels
Tip Start
For More Info, Call 888-539-7474
1-Yr. SiriusXM Radio Service
Manuf Statement of Origin
5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TB
Customer Preferred Package 24B
SEBC Owner Care
Distribution Services Tracking
Aftermarket wheels... ...what size tires? Smallish tires might make a stocker look lifted.
Also, read the digits off the tags on the springs. If HD springs were put on it would lift it an inch or so.
optional package references 4 springs. So, perhaps your Jeep came from the factory with a stiffer spring rate. I'm not too familiar with how optional equipment availability for suspension. However, I know that swapping Rubicon coils & shocks from a 4 door onto my 2 door sport gave my Jeep around 1.5" of lift.
while we're on the subject...
I have a 2007 wrangler 2 door. It wanders all over the road. it IS lifted. I just ordered all new bushings for every suspension piece front and back. so here's the question: on the two post lift hanging from the frame the rear sway bar is pushing against the tire on the drivers side, 2-or 3 inches away from the tire on the passenger side..is this normal or should I drive it off the nearest cliff???
George in Montana, old fart like to do stuff myself..
most likely someone installed coils from a 4 door rubicon so you have a little lift.
Your rear track bar moves in an arch. Since it's attached at the frame on the passenger side and at the drivers side on the axle, the rear axle will always shift towards the passenger side whenever the vehicle is raised. If you describe it as being lifted and it is still using the factory rear track bar, chances are your axle is shifted towards the passenger side even at ride height.
Discussion Starter · #17 ·
Currently have 255/75R17 tires.
stock suspension. Get out your tape
I bet you're going to find that the springs and shocks are donated from a heavier Unlimited and that accounts for your mild lift. I did that to my 2-door when I had one and it worked for 33" tires until I added bumpers, winch, sliders, etc. Then you need 2.5".
So you have a lift but you don't have a lift. That make sense?
Reactions: nworker
Discussion Starter · #20 ·
Another Newb question. So my JK originally had 225R75/16 tires and had a 3.21 Rear Axle Ratio. I know have 255R17/17 tires. Does the gear need to be changed? Since I purchased it used, I really have no idea if it has.
1 - 20 of 30 Posts
