My TJ 4 cylinder 5 speed has a bad stutter when taking off. Almost like I can't drive stick type of Shake. Jeep shifts fine and everything clutch wise seems fine. Just trying to figure out what could be wrong with out taking it to a shop.
I looked at engine mounts they appear to be decent, no cracks or tears in them.
Mostly old school..!
Try putting it in 4wd high on a straight path in a parking lot. Then take off like you normally do. If the shudder goes away in 4wd, the issue is most likely your transmission/t-case mount.
Is it kind of like a vibration when releasing the clutch and goes away ones the clutch is fully released and you are driving in gear?
Mine does the same thing after my lift. Is it nessesary to replace right away or can it wait till next weekend on my next day off.
No not necessarily. Only in first or reverse, if I am rolling the tiniest bit it doesn't happen. If the clutch is fully released it will still do it just a little longer. It seems if I ride the clutch a bit it doesn't happen.
Your symptoms are why I swapped out my mount and it did the trick. Try to avoid the poly type mounts as they transmit a lot of vibes, stick with the OEM rubber if you can.
