I have a 1995 wrangler with a 4 cyl / 5 speed. I ask because I put in Gumout fuel injector cleaner for high mileage yeasterday and the bottle said for up to 21 gallons, it didnt have a # for the least amount of fuel. I am wondering if it is to concentrated, and may hurt something.
Administrator
should be okay, with the amount your put in. I want to say the 4cyl has a 15 gal tank the 6 has a 19 or 20 gal.. though If I also recall the only real difference is there was removable bladder/filler box you can take out of the take if you have the smaller version to get the full 19 gal.
most fuel injector cleaners are naptha(zippo lighter fluid) based. its a very mild petroleum cleaner. you could put several bottles in and wont hurt anything.
gasoline with ethanol causes more problems than FI cleaner.
It shouldn't hurt anything and if like 4Jeepn said you really have a 20 gal tank. From the factory Jeep put 20's in all jeeps at least 1991 up to 1995 to save money.
If you can use a pair of pliers and a screw driver you can do the mod at home to get the "20 gallon".
Here is the link for the do it yourself'r.
YJ Gas Tank 15-to-20 Gallon Conversion
