Can someone tell me the stock measurement from top of axle tube to bottom of frame for front and rear to determine how much lift this tj has. TY in advance.
that might be a tough one due to sagging and age. Good luck with finding how much lift it has. If it has spacers on top of the coils, its probably two inches. If it has aftermarket control arms, maybe 3+. Usually you dont keep the stock arms if you go much over 3.5-4 inches.
Lift was installed by PO 2 back. The guy I bought it from didn't know much. No spacers, and after market lower control arms. The front left shock is blown and I need to determine how much lift it does have to get the correct length shocks.
Thanks Shark!! Just found that out reading another thread...
