I recently bought a 2004 TJ Unlimited that I’m trying to figure out what size suspension lift it has. A couple of facts...1.5” body lift and 37x13.5x20’s with 1” wheel spacers if that helps. Any ideas how to do that? What other information would be helpful?
If I remember right the front springs are 11 inches and 8 in the back, that's unloaded. Any more than that will tell you your lift
Sent from my SM-G973U using Tapatalk
How are you defining unloaded? Jacked up with the wheel off the ground? Or removed from the chassis?
Removed. Jacking till the tires are off the ground may stretch the spring longer than they are when removed from chassis
No problem, but I will mention it that I'm not sure those are the correct length I maybe a little off. If your on 37s it's better than a 4inch
