1 - 13 of 13 Posts
Hey osborn can you post a pic of your jeep with the 2" bb lift cause im getting a lift this christmas and i going go for the 3" lift from rustys offroad and i wanted to see the diffrence. thank you. :cool:
i got the rustys 2" coil lift and got 2.5" out of it. its great and it clears 32's very nicely also.
rocker panel before
19"
after
22"
so actually thats 3 inches which is weird cause i could have sworn that the first time i measured it right after i put it on that it was only 2.5" but when i measured again after i had it for a little while it was 21" sure enough and i had the before measurement written down so i know the before isn't wrong. (and don't tell me the tires lifted it some because the tires were installed when i measured before the lift)
before the tires i think it was 18" to the rocker panel
If your measuring at the rocker panel, you also have to allow for the inch you gained from the new tire size.
true but like i said when i measured before the lift the 32's were already on and so im of course using the same tires now with the lift. so the tire size wasn't a factor since they were installed when the measurement was taken.
Hey bigjeep im haveing a hard time buying a lift and now i want the 2" that you have on and wanted to know if you needed a tcase drop or if you had any vibes its going to be for 05 lj and how do you like the ride a offroad proformance and if hear and suspension nosie thank you dude. :cool:
i love the lift. i didn't need a t case drop because i didn't have any vibes. since you have an LJ you definitely shouldn't have a problem with vibes since you have a long driveshaft. you should not have to do the t case drop. i don't hear any suspension noise and i get a lot of travel out of the lift. it performs really well offroad. flexes really well.
1 - 13 of 13 Posts
