Put it into 2wd(as best u can tell) and try turning the front driveshaft. If it spins freely then you indeed are in 2wd.
well lifted the front wheel and tried turning the front prop shaft ..wheels turn in both 2h and 4h.....now i have to figure out how to adjust the shifter since the trunnion is rusted on the adjuster shaft....:banghead: basically I'm stuck in 4h ....Put it into 2wd(as best u can tell) and try turning the front driveshaft. If it spins freely then you indeed are in 2wd.
yea don't do thatGo find a parking lot or other area big enough to mess around in. Ensure it is in 2WD then turn in a tight circle.
Then put it in 4-high and try turning in a circle again. I know I can certainly feel a difference when its in 4-high. Its way more "grabbier." The tires even bark a little.
You can easily tell it's in 4-low due to the revs.
x2severedistortion said:yea don't do that
LmaoSinfulDragon said:Park in mud hole
put in 4HI
turn wheel to the right
stick head out window
floor it
compare the amount of mud/rocks/sticks on your face to the amount on the back of your head.
if equal parts, 4HI is working
if only the back of your head is covered, its time to look at the linkage.
yea don't do that
Park in mud hole
put in 4HI
floor it
yea don't do that
I personally do not see an issue with this. I have driven on my street some while in 4WD to make sure it's working right. Unless you are already on jack stands, this is probably the fastest way to find out if it's working or not. You don't have to make tight circles or go fast...you will feel more traction with the front tires just making small turns right and left. Granted, this isnt recommended for everyday driving...but a little asphalt time isnt gonna cause your jeep to explode. Think about it...if 4WD on grippy surfaces killed jeeps...no one would wheel Moab :whistling:woah.. this is how i check to make sure im not in 4WD (and if my 4wd is working), why would this be a bad idea? Serious question :-O
to clarify, i dont exceed 5mph when doing this.
