I am looking for ideas of how to get some more travel out of my suspension.
I have a YJ with a 4in SUA rough country lift. Sway bar disconnects, 1.5 lift shackles. The lift prob has less than a few 100 miles on it. So I guess it still has some breaking in to do.
The only other thing I know to do other than letting the springs get some more rough terrain under them is to remove the trac bars which I plan to do. Will I notice a dramatic increase by doing this?
Any other ideas?
Yes removing your trac bars will be a big improvement.
Unfortunatly the leaf sprung YJ's are limited in the ammount of travel you can get out of them.
I lowered the torque on my springs and it made a huge difference. Solid frame side at 70 foot pounds. Shackle side 50 foot pounds. I drive mine everyday no issues with this torque specs. Also no track bars or sway bars. The springs will break in some as well especially when you go off roading.
if they have a miltary style double wrap cut it off the front side so it ends about 1/4 of the way around the bushing circle. Also you can cut and bend the bands that hold the springs together so they look like |_| to allow the leaves to separate when the droop out. on your shackle bolts anywhere between 30-50ftls seems to work well. Sadly at the end of the day 4inch lift YJ spring is going to be stiff. 1 because its so short and 2 because of the amount of arch it needs to give the lift height.
