1 - 1 of 1 Posts
Here is a link to the video I made of installing an Aussie Locker in my 2003 Jeep Wrangler Sport Dana D35 Rear axle. Hopefully It shows enough for you to decide if you want to attempt installing one. The instructions make it sound scarey because they cover nearly everything that could go wrong and talk about pulling the carrier/ring gear out. but unless you have after market gears that are thicker the ring gear don't get in the way. I guess all I really can tell you for sure is that on my d35 with 3.07 gears this install was pretty easy. I does change how you drive if you give it to much gas in a tight turn it will chirp a tire. I have not had it in the snow yet but I have had older posi traction rear end in other vehicles and so I don't think it will be an issue. I can hear the click when I give it gas through a corner but if I coast it is silent from inside the jeep. remember to read the instructions and do the test after the install and before you drive it. IMO very easy mod:punk:
How to Install an Aussie Locker Dana D 35 - YouTube
1 - 1 of 1 Posts
