1 - 9 of 9 Posts
Well maybe not theft proof. I am installing some high dollar lights on my LJ. Anyone come up with a way to make them harder to steal??
Once they're on, and in place, tack weld the bolt to the nut. Or you could use some Loctite epoxy on the threads when you put the nuts on. That should do it.
You could use a bolt and castle nut and instead of using a cotter pin you could put a small lock like you'd find on the zippers on luggage. May not prevent theft, but definitely will deter it.
Founder, ThumbJeeps
I like the spot weld idea. Could always grind it off but the avg. theif isn't going to have a compressor and cut-off saw. Good thinking... Im also considering a hidden kill switch.
1 - 9 of 9 Posts
