1 - 20 of 22 Posts
My 2016 wrangler stock license plate holder will does not fit my porcelain shorter license plate very good at all. as you all know the OEM mount is set up for a full size tag. Is there any good way to mount a shorter tag? If not what do I need to buy aftermarket and where can I find these mounts. I cant seem to find them online .… ??
I'm new here !!
Thanks in advance !!!!!:jawdrop:
What is a “porcelain shorter license plate”?
Reactions: CTarna
Retired Moderator
:welcome: to the Forum..:wavey:
Cut a piece of sheet metal to the size of a standard tag, punch holes where they should be, paint it, mount your tag to it, mount it.
Where are you that you're running a squirrelly tag like that?
Reactions: Phynal
Okay! So many specialized plates these days I thought what have they come up with now.
:beerdrinking:
Seems a strange sort of fetish, doesn't it?
I could see putting one on something of that vintage or on the front in a state that doesn't have front plates. I used to have a Euro tag on the front of my MINI Cooper...
Yeah, but why put a not legal tag on the back? Unless it’s a strictly off road vehicle. Maybe the original poster will explain?
I believe you can still get plates in that size in Delaware. I see them when we take my Chrysler on our annual trip to Ocean City, MD and drive from my in-laws near Philly down all the way through DE. Narrower black tags. Just not porcelain, obviously.
It's a Delaware thing. Tags are transferable, and people pay money to buy "low digit" plates off of each other. The snaller/shorter the number, the more expensive.
Sent from my SM-G965U using Tapatalk
Good idea, it's my girls jeep, that should answer that for you ..:bop:
Della-where?
I went to the U of D. Go Blue Hens!
....didn't know I could've had a squirrelly little tag though....
These are current-issue tags, or old tags the state DMV lets you re-register?
Wouldn't apply to a JK of course, but in most states you can run older plates on vintage cars -- but only as long as it matches the model year of the car. It would be pretty cool to have a 40's Jeep with a 40's tag. Lost of square or near-square shapes from the 30s and 40s, although most states started using the same shape we have now starting in the 50s. I gave a friend a 1926 tag I found in a barn for his 26 lowboy hot rod, those were short and wide, similar to European tags.
Reactions: Hilldweller
1 - 20 of 22 Posts
