How do I reset the oil change light? It recently came on and I changed the oil. Thanks guys.
Here you go (copied of internet)
The*oil*life system can also be*reset*as follows:
Turn the ignition key to position “RUN” without starting the engine, If your vehicle has a Smart key button, press the “Start” button twice without touching the brake pedal.
fully depress the GAS PEDAL slowly three times within 10 seconds.
Sent from my SM-G955U using Tapatalk
Thanks. I’ve tried several different thing I’ve found on the web with no luck.
I've used this method, it worked on 2016. If you go to fast depressing the gas pedal it wont reset the light, so depress it slow.
