I have looked at other treads and found that the ECM may have a bad relay. When the driver door is open it rings. where is the door switch. I cant find where it might be located. The key does not have to be in the switch. I would like to either disconnect the switch or unwire the bell
I believe the switch is in the door latch mechanism in the door.
I wish I could find the switch to turn off the ringing I hear constantly - alas, I'm stuck with it; at least the VA pays me a bit of money each month for putting up with it!
I found 2 wires in the braded door check strap. I nipped the purple wire and that was the fix. The strange thing is now the radio is always on. But at least the ringing stopped.
Try going into your settings menu and set the accessory delay to 0.
That should turn your radio off as soon as your turn off the key
