I got a TeraFlex antenna bracket for my TJ's rear taillight that holds the CB antenna. I worry water will cause issues if it gets inside the connection between the cable and antenna.
Is this an issue? If so, how do I prevent it?
Not sure what you mean but I have never heard of such a problem. Mine is fine after all this time.
If it's screwed together nice and tight, there should be no problem from rain.
If you are going to submerge it, then a good wrapping of electrical tape, or find a product called Coaxseal. It's a rubber compound in tape form that binds to itself.
