ATX AX 195 Cornice
Very similar look , Teflon paint.
I haven't seen an AX 195 in person but, most of the fake bead locks look pretty...well…..fake when I've seen them up close.
At least the bolts are recessed in the wheel dish out of harms way and not as likely to be ground off on the trail like bolts mounted to the rim area.
For what its worth the Rockmonsters have plastic bolt covers I assume to keep the bolt threads clean.
Off the shelf the ATX 195 is about as close as you can get. What makes the Hutchison's "look" different from the simulated beadlocks is that they have have studs with a nut. If you really like that look you can take one of several split spoke wheels, add OMF rings and replace the bolts with studs and nuts.
