i just bought a 1991 jeep wrangler, 4.0 L, 6 cylinder.
it has new:
Fuel Pump
Fuel Filter
Plugs
wires
Coil
throttle position sensor
oxygen sensor
and auto idle moter
there is a slight oil flow in #1...
it wont idle, it dies when clutch is let out (orput in gear), there is some backfiring before it dies.
the code reads 33, which means an A/C problem according to the guys at auto zone. the only problem with that is that there is no A/C in it.. so i am kinda lost.
does anyone know what could be wrong with it?
Code 33 is just telling you that there is no relay switch/fuse in the power box under the hood for the A/C. This is 100% normal since you don't have A/C. The problem must lie somewhere else. Check your fuel pressure and Crank position sensor.
ya, code 33 is nothing.
i'm concerned about oil in #1, how did you determine this? cuz that is a big problem. and backfiring could be an indication the timing is off.
are you sure the firing order is right, maybe backfiring is just bad misfiring. and i didn't see cap and rotor on the tune up list, those can't be ignored.
hey thanks ill check the cap and roter. and most deffinetly the firing timing. ill let you know if that works.
