When it rains, then I drive my yj ,I have water runing on my feet.Is my cowl gasket bad? It comes from under the dash somewhere.
By cowl gasket do you mean between the windshield and cowl or between the cowl and back edge of the hood? I was getting water into my fuse panel until I replaced the weatherstripping under the windshield.
Replaced the cowl (under windshield) and my leek stopped but I know if your actual cowl (vent at read of hood) is clogged it will do the same thing. Check drain first only takes about 2min to pull it and flush the hose out.
Check both and best of luck
thanks ,I will do that
