Need help guys & girls, Still no spark & no fuel! STILL CRANKS STRONG BUT WON'T START.:banghead:
Here's the list of what I've done up to this point;
INSTALLED NEW---cap,rotor,wires,coil,cam position censor,crankshaft position censor,plugs,ever fuse & relay.
Cleaned & Checked all grounds, electric connectors, bat. terminals and continuity check all circuts.
Just finished going through the entire wireing harness in engine copartment & behind the dash.
ANYONE HAVE ANY LAST THOUGHTS BEFORE I SET THIS THING A BLAZE!!!:firedevil:
Get a match.
Hold up there sparky! Lets take one thing at a time.
What motor do you have and what year?
How do you know it has no fuel? If it's injected, have you check the fuel rail for pressure?
Administrator
90 YJ fuel injected. (according to his profile)
burn burn burn!!! sorry i have nothing to offer but good luck with the rig
rogertc1 has it right. You've done what you can do. It's time to learn something new.
Don't ever mix up advice from Drivers from a good Mechanic.
