i have a 87 jeep wrangler yj i need the chrome surround that holds the air fiter on top of the carb that your y nut screws down on to hold the filter in place...
i can not find this anywhere.......does anyone know where i can get one... thanks !
dont want you to think noone is reading, but i'm unfamiliar w/ the part you need. are you talking about a circular "spacer" that sits inbetween your air cleaner? what is the diameter? cuz if so there are bunches of them out there at different heights.
If you have the 4.2L with the stock Carter carburetor (BBD 2BBL) then you need the small one (Mr.Gasket 4") from the big box store. (Autozone, Advance Auto)
If you decide to upgrade to the MC2100 carb, then you can use the 10" Edelbrock or Mr. Gasket chrome air cleaner.
yeah i have a stock 4.2 with the carter carb, i have the air filter, just nothing to hold it down on top of the carb.
The air cleaner consists of (1) the base that fits over the carb. (2) the filter element.
(3) the lid. (4) the 1/4-20 wing nut to hold it all together.
Are you saying you need the lid?
Junkyard maybe.
