Wrangler Forum banner
1 - 16 of 16 Posts
I'm getting the bearings pressed on, how hard is the rest of the job? I'm pretty good with cars, I've done all of my work.. Just never done axles.. What tools are required? And about how long will it take? Thanks!
Almost all the vendors will ship you 100% bolt in ready axles ? Northridge was doing 10's for $450
so I've got bent axle shafts, so I'm switching to these hoping it will make it all a bit stronger in the rear.. The shafts won't need to be pressed into the axle housing, will they?
Bearing pressed on seals and retainer clips, slide the axles in ,four flange bolts good to go.
Discussion Starter #6
What about pulling the existing axle out? Does that need any special tools?
Discussion Starter #8
You still own a 07 ? The only issue I see you facing is Rust. Have a Mapp torch ready. Those hub bolts tend to break.
yeah I do. So after I get the rotors off, I just undo the hub bolts? How many bolts are there?
1 - 16 of 16 Posts
