I have finally decided that I want to do a lift on my TJ. So my current setup includes:
No current lift
1.5 inch wheel spacers
31 X 10.5 on the stock rims.
I want to do a lift that will allow me to keep what I have now but eventually be able to upgrade the wheels and tires to a 33 inch tire in the future.
So my question is, what size lift should I go with? If any of you can suggest a specific lift, I will take your advice and most likely order it. Best advice wins and I will definately put it up on the website.
You can fit 33s with a 2.5 lift without having to do SYE and that stuff. If I was to redo it I would go with the OME lift instead of the 3.5 Rock Krawler I have.
OME suspension kit, 1.25" BL, 1" MML and you should be fine with 33's as long as you have the correct back spacing. Plus no worries for SYEs, TC drop kit, linkage adjusting, or fan shroud trimming.
Here's what I have. Click this LINKY and scroll down to the "ultimate" kit. I'm very, very happy with it. Here's what it looks like on my rig with 33x12.50.
I think this all sounds pretty great! I do not do too much off-roading here. I am just looking to do something that will raise what I currently have up a little higher but also give me the oppertunity to eventually put 33's on there.
So with a slight lift, will I still be okay to run my 31's? I don't want to screw anything up here. Hear where I am coming from?
I would do like the above said that will not only make it possible for you to run 31s and 33s but you will also save bunch of money not needing an SYE. Thanks for rubbing it in AS. ::kidding::
I don't know anything about lifts only what i have read on here, i really like the 33x12.5s. would I have to get new rims or can i keep stock? If I get 33x10.5 could I keep stock rims?
Yeah I would go with the 33 X 12.5's so I would I have to get new rims....which is no problem.
Ageless Stranger, I think I like your setup and I think I would go with what you have there. Do you think I could still run my 31 X 10.5s with the 1.5 inch wheel spacer on that setup?
The reason why I am doing the lift first and then the tires / wheels is because of the amount of money it takes do undertake all of this.
Yes you can run 31s until you can buy your 33s. If I was going to do that I would install only the suspension lift and shelve the body lift and motor mount lift until you can buy the 33s. You'll get all the flex you're going to gain up front, and the body lift will give you the extra clearance you need to go to 33s when you can.
I have a question for you. Why are you running wheel spacers with 31x10.50s?
I was getting some tire rubbing So I decided to widen the stance out a little bit more. It actually looks pretty good. I'd hate to shelf all that stuff but maybe it is a good idea.
I didn't realize how expensive all this can actually be I should have gotten it done when I first bought the Jeep haha. Oh well.
