1 - 11 of 11 Posts
Vehicle Description: Jeep Wrangler Sport 4X4 Sport Utility 2-DR
Model Year: 2002
Body Model: TJ J H 77
Build Date: June 14, 2002
In Service Date: July 15, 2002
Sales Code Description
*L5 Cloth High-Back Bucket Seats
-K5 Camel
AACS Convenience Group I
ADCS Convenience Group
APAS Monotone Paint
A23P 4.0L Engine(ERH)/3Spd Auto Trans(DGG
BAUS 117 Amp Alternator
BCDS 500 Amp Maintenance Free Battery
BGK 4-Wheel Anti-Lock Brakes
CADP High Back Bucket Seats
CAGP Easy Access Passenger Seat
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CKTS Cargo Tie Down Loops
CLC Front Floor Mats
CLSS Sport Bar w/Rear Padding
CUFP Full Length Floor Console
DGAS All 3-Speed Automatic Transmissions
DGG 3-Spd. Automatic 32RH Transmission
DHAP Lock-Up Torque Converter
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRJS 175MM Rear Axle
DSA Anti-Spin Differential Rear Axle
ERH 4.0L I6 Power Tech Engine
GBBS Tinted Windshield Glass
GCBP Front Door Tinted Glass
GCD Deep Tint Sunscreen Windows
GCFS Full Metal Doors w/Roll-up Windows
GFAP Rear Window Defroster
GRVP Left Manual Mirror
GSVP Right Manual Mirror
GTVS Swing-Away Mirrors
HAA Air Conditioning
I74S Route 74 - UP, Westfield, TX
JAYS Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJAS Cigar Lighter
JJFS Single Low Note Horn
JKAS Locking Glove Box
KFRS STRIPE/BADGE/MOLDING/COLOR
KWRS STRIPE/BADGE/MOLDING/COLOR
KXRS STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR
LBBP Courtesy Lamps
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MB5S Black Rear Bumper
MCHS Painted Lower Fascia
MFPS Chrome Headlamp Bezels
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MWBS Sport Bar w/Side Padding
NAS 50 State Emissions
NBKS EVAP Control System
NBVP Low Emission Vehicle (LEV)
NF1S 19 Gallon Fuel Tank
NHM Speed Control
PW1 Stone White Clear Coat
QW1S Stone White C/C
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TMSS P215/75R15 RBL Wrangler AT Tires
TZAP Goodyear Brand Tires
VKT Mango Tango 3-Piece Hard Top
WJ5S 15X7.0 Full-Face Steel Wheels
WKBP Matching Spare Wheel
WLYC All Steel Wheels
XCYS Delete Remote Start System
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWS 2 Front & 1 Rear Tow Hooks
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
XWC Warranty Registration Card-Govt Bid
YAAS Build To U.S. Mkt. Specifications
cool.
i see the options on your Sport are the automatic trans, Convenience Group, speed control, anti-lock brakes, and 3.73 axle ratio...I believe the rest of the build is standard on an '02 Sport right?
where did you get your build sheet data?
There is a link on jeepslimited.com to get your build sheet. Just enter your info and I believe the last 8 of your VIN. Takes about a day to get response.
yes thanks for that info.
Compnine is also back up. You can do a free VIN lookup at least once a day. It varies. I've seen it where you could do 10 in a day for free. I'll have to check out the one at Jeepslimited.
yep, took about 12 hours to get mine:
2002 Sahara
*M5 Cloth High-Back Bucket Seats
-KG Camel/Dk Green
AASS Tire & Wheel Group - 30"
AEM Dual Top Group
APAS Monotone Paint
A68P 4.0L Eng(ERH)/5Spd M/T Nv3550(DDD)
BGAS Power Front Disc/Rear Drum Brakes
CLCS Front Floor Mats
DBBC All Manual Transmissions
DDD 5-Speed HD Manual Transmission
DRKP Dana 44/226MM Rear Axle
GCDP Deep Tint Sunscreen Windows
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
I89S Route 89 - CSX, Selkirk, NY
JJAS Cigar Lighter
KBTS STRIPE/BADGE/MOLDING/COLOR
KWPS STRIPE/BADGE/MOLDING/COLOR
KXPS STRIPE/BADGE/MOLDING/COLOR
K5XS STRIPE/BADGE/MOLDING/COLOR
LAPP Shift Indicator Warning Lamp
LBBP Courtesy Lamps
LDAP Underhood Lamp
LNJS Fog Lamps
LPSS CHMSL Lamp
MRJS Bodyside Side Steps
NHMS Speed Control
PX8A Black Clear Coat
QX8S Black Clear Coat
RBRS AM/FM Compact Disc Radio
RCUS 7 Speakers Inc Subwoofer/Tweeters
SCGS Leather Wrapped Steering Wheel
SDUP Heavy Duty Suspension w/Gas Shocks
TUSP 30X9.50R15LTB Wrangler OWL A/T Tires
VJTP Dark Tan Soft Top
VKTA Mango Tango 3-Piece Hard Top
WJXP 15X8.0 "CANYON" Aluminum Wheels
WLZC All Aluminum Wheels
1 - 11 of 11 Posts
