1 - 20 of 75 Posts
I'm a JK and JL builder... Literally 100+ through the hobby shop in the last 4 years. When a TJ came in, I steered clear as my experience didn't contribute to the build.
I stumbled upon a completely stock LJ Rubicon and bought it... Pics after the rear main seal is replaced.
If I like it, I will go in pretty deep in the end, long arm on 37's or 38's... But for the next 8-10 years, I want a quality driver on 33's. So poking around, I see a lot of Zone 4.25 combo recommendations... I'm not against that, just can't stand their JK stuff, so I'm hesitant. Shop owner says RE... Again, not my favorite.
I have a line on a set of the Core 4x4 tier 4 control arms with double Johnny Joints so I know those will be good.
My request is for you guys to give me what your top 2 setups to run 33's would be.
Example:
Zone 4.25 combo
Full set Currie control arms
MC front track bar
Etc.
Thanks in advance.
If daily driver on 33s means either no wheeling or light wheeling then 2 Inch spacers and a 1.25" body lift will get you there...
You won't find many long arm fans here... myself included...
Discussion Starter · #3 · (Edited)
Nope, it will be wheeled and weekend warrior. Relatively challenging trails here in AZ. I know the LA perspective here, and I'm cool with that... But there simply isn't any big builds here running short arms. But that's way down the road.... Today, tell me how you would build a short arm crawler on 33's. 🙂
Reactions: SubmarineAZ
Fraid I can't help ya much there... I have zero interest in crawlers and I do most of my wheeling on leaf springs.... plenty of others will chime in soon tho...
Just do a curry 4 inch lift. It will clear the 33s just fine. Comes with the antirock.
It does work well as a package.
I would recommend gearing, I have a 2004 LJ and went 5.13. Wish I could have gone lower, but I don't have a rubicon. You should be able to go 5.38, do it.
35s need a body lift and the things associated.
Bigger than 35s? Probably cheaper to buy a newer jeep...
I wheel by LJ whenever and wherever I can. Isn't that what the winch is for?
Zone combo lift, MC adjustable track bar and Rancho rs5000X shocks. There's no need for long arms or going larger than 35s. Jerry B in bottom pics.
Reactions: Pressurized
I have a 2003 TJ on 33s.
She sports a three inch Savvy lift with a one inch body inch. The one inch body lift works in conjunction with a one inch engine lift and a Savvy tummy tuck. The tummy tuck gives a couple three inches more break over while keeping the CG down. Heavy duty Currie tie rod and drag link. She also has a matching Savvy Gas Tank Skid. This saves weight, looks good and gives another inch of clearance in the back.
The savvy dual adjustable control arms also allow for pinion adjustment for the SYE kit and Tom Woods dual Carden drift shaft.
My 42RLE likes 5.13 gear sets in the front HP30 and rear D44. The axles have Fox 2.0 shocks. I live in a no snow or ice climate and my elderly parents are in Tucson. So, Detroit Lockers in the front and back along with a Terra Two low kit in the transfer case.
To improve braking the HP30 has a Vanco Big brake kit(knuckles modified to use Ford Explorer dual piston calipers).
For 35s this same build is often used except with a four inch savvy lift.
With Centerline aluminum wheels she will go straight down the freeway at 70 like she's on rails. The wheels have 4.5 inch BS to keep pretty much under the flairs but the tires don't rub.
There is more I suppose but that hits the hi lights of my suspension.
I have a 2005 on 33's with 4.88 gears. DPG has a good Old Man Emu set up that will clear 33's just fine and will ride really well (for a Jeep TJ/LJ). It's a 2.5ish lift with a 1.25 body lift. I know a lot of folks don't care for a body lift. But a 1.25 doesn't look bad and gives you just a little extra.
"For 35s this same build is often used except with a four inch savvy lift."
I am pretty sure Jerry B. is using a similar Savvy lift with 4" springs in the above pic of his short arm.
I have two jeeps and the one on the zone 4.25 kit can go pretty much anywhere my much more upgraded one can. the way I see it you have three budget points.
budget build: zone 4.25" combo, MC or currie adj front track bar, and 33" tires. that will set you back ~$700 plus tires
not so budget build: 1.25" BL, 1" MML, currie 4" coils, outboarded fox 11-12" travel remote resi shocks, anti rock, savvy control arms, adams drive shaft, tummy tuck, raised GTS, and a bunch of other little things for around $3500 plus 35" tires.
best build for stock axles, the above build with the Savvy mid arm kit, add ~$3000
if your willing to do the work to install an LA........... maybe take a peek at Savvy mid arm. i recently moved into the "mid" range and like it way better than the SA sys.
way better movement than the SA sys and not as greedy into that belly space as the LA's.
DAX - any more pictures from the side? Looking into the OME for our '04, but not sure about the body lift...
Discussion Starter · #14 ·
just an FYI, every jeep in this thread except for the OP's has a 1-1.25" BL
I understand the BL goes well with the 1" raised MM. I intend to do that. Will also tuck all I can... Sounds like the Zone Combo and the Currie 4" are the preferred options... Also going to check out the Savvy mid as that will be less $$ than the custom coilover and long arm.
Will Also look at what DPG has... No doubt Dirk is good with OME stuff.
It has to get me to retirement on 33's... That's around 8 years.
After talking it over with my wife last night, the fact that I got a Rubi instead of a sport kills the end game idea of axles and 38's...
Discussion Starter · #15 ·
I think the body lift is pretty common in the TJ/LJ world. And works well in conjunction with the motor mounts. In a JK or JL we would never use a BL.
I've had many Zone lifts, including my newest Rubicon with 35s. Since they discontinued their nice riding hydro shocks, I would opt for Rancho rs5000x. I'm going to try some on my XJ with 5.5" lift soon. I hope Jerry B is right about the ride quality. It's so subjective.
OME used to be good when they had the nice riding yellow shocks. Those days are gone and the newer black shocks ride too stiff for most TJ folks.
Discussion Starter · #18 ·
That's beauty you have there!
Really good info on both... My next question was going to be "are the zone shocks any good"...
I was an early adopter on the 5000X shocks on my JK. Had them right after they were released. Damn good shock for the price. I now ride on Falcons on the JK and FOX for the JL. Have also ran 9000XL's on the JK, I like the Rancho's, just have to do a little work on the finish before install.
Can you buy the Zone lift without shocks?
Thanks. I always used the Zone hydro shocks and they rode great IMO. The nitro shocks get reviews of being too stiff, just like the newer OME shocks. Jerry B said he drove a Jeep with Zone hydro shocks and they were too soft around corners for him. That's why I always say shocks are subjective. I'm going with the Rancho rs5000X shocks next (on my XJ) to give an honest review. I did one of the first reviews on Zone lifts when they first came out. I have the 9000XL's on my Rubicon and he said they're still too stiff on the softest setting. Time will tell.
Maybe I should clarify. My 3" savvy lift is in the coils. and the 1" BL is on top of that for 4" total.
A 35" tire build would be 4" coils and a 1" BL for a total of 5".
1 - 20 of 75 Posts
