1 - 20 of 40 Posts
Hardcore Jeeper
Sticks are harder to use / learn with. Migs are nice, just pull and go.
Sticks can go up to much thicker gauge material
How serious are you about getting into welding? I have a friend that bought a harbor freight special 110v gas less mig (uses a different type of welding wire), and he can do just about anything with it, and its still going strong a few years later. My dad went out and bought a nice miller mig with gas that has also given us years of trouble free service. At about 4x the cost.
Also, don't forget your garage electical needs to be up to par. and if you go with a 220v stick welder, you will probably need a few more 220v outlets installed so you can weld on and off body...
Rock-Rubber
Assuming you have the wiring to run it, go with the top welder. It's the one I learned on, taught myself, and do all my welding with now. Plenty of power. He'll you can basically cut with it like a plasma if you really want with a little practice. You will have to learn. It will not start pretty. Either get good advice or find someone who knows what they are doing to get you started. Try different techniques and see what works. I have some good resources for arc welding if you are interested and will offer advice as well if you get to that point.
Some examples:
Rock-Rubber
220 with the right breaker, I believe it's 50A, and heavy enough wire to run. Also depending how things are set up if you will meet code etc. If you care about that. We ran all new wire and set up a new box etc then ran to the 220 outlet for the welder a few months ago so I could weld up at the garage too instead of only at the farm. Do you have 220 in your garage?
All 120s. I mean, I've got a 240 dryer plug, and a generator with a 240 plug also.(live in Louisiana) it wouldn't run on 240?
I started with a cheap wire feed flux core welder from tractor supply. Now I've got a Lincoln MIG 140 and it welds anything I need fine and it runs on 120 regular outlet.
jherrington said:
She's mine!
Ah 225 stick/arc nice. I almost picked one up to practice my stick welding but didn't feel like messing with the higher voltage requirements and the fact it can't TIG. How do you like it though
Discussion Starter · #13 ·
Haven't tried it out myself yet. I need the plug adapter. I got the guy to show me it works and everything else.
He told me he had only used is a few times and it has been kept in his shop all if its life.
I was told it was a good welder to start off with, so we will see.
Rock-Rubber
We have the older model of it at my farm, it's well over 30 years old from what I'm told. These things literally last forever. And once you learn how to use it, will lay some of the strongest welds out there. They don't look as pretty as MIG until you learn what you're doing but they can be pretty once you get good.
That it is. Both Lincoln and Miller lead the welding industry it's just a matter of preference. You can weld anything vehicle wise with that stick welder just practice when you get it set up. There's a lot more to welding than just sticking metal together but once again nice buy
What's the model of the one you have is it an SA?
Rock-Rubber
both models I have are the AC 225. The one in my garage is exactly as pictured above. The one at the farm is very similar, just old as dirt with different label printing and slightly different shape/color.
Which model is the "SA"? I didn't buy it new so I'm not sure.
Oh nah you'd know if you had an SA 200 it's got an engine built in to it to power it. I was just asking because I've seen a lot of farms selling old SAs it's a stick welder that has its own generator and can weld at 100% duty cycle so you never have to stop. Old but one of the best. I was asking because I want to start pipeline welding and that's the perfect welder for it
1 - 20 of 40 Posts
