1 - 13 of 13 Posts
'02 sahara auto - 118,000 mi. activated cruise control @ 55mph - speed immediately began increasing ! - at about 60 mph i realized something not right - cruise control would not de-activate and speed continued to increase ! slightly rattled i began braking. the brakes struggled to bring jeep to complete stop and engine continued to try to overpower the brakes. as fate would have it i was about a block from my mechanics shop ! just removed foot from brake and jeep accelerated up to 45 - at which point i pulled into shop again forcing to a stop with brakes. turned off engine. restarted and engine immediately revved to very high rpm's. turned off and i am awaiting diagnosis. anyone experience this scary scenario ?
Time to take the fuse out for the Cruise Control and go OLD SCHOOL!! Too scary.
Reactions: Blondie70
Lol, this thread reminded me to order a cruise control kit for my 97...
02 TJ
Cruise control throttle cable get stuck or something?
Aftermarket CC installed.
Most likely Throttle Position Sensor. I had that happen to me in an '89 XJ (in early 1990). I went to lunch - all was fine. Stopped for gas and wham reved up to 3,000. I thought it would throttle down when in gear, but it didn't. I had to control it with the ignition switch. Fortunately didn't have to drive in much city traffic. Limped to the dealer after work. Fixed under warranty. I put another 80K miles on it and never had another issue with that Jeep.
Discussion Starter · #11 ·
follow up w/ diagnosis - yes, stuck cruise control cable - easy fix but glad i was not in heavy traffic (yeah shifting into neutral and turning off ignition would be thing to do)
An electrical issue, this being one, is hard to diagnose. So the only suggestion is that you thoroughly check everything electrical starting with the battery; age, cables, terminals, posts, and etc. And Ground wires and etc.
Happened to me once, luckily I was on a relatively quiet road and able to drop to neutral and pull off. I turned off cruise and restarted with no luck. Since it was late and only a few miles from a dealership I had AAA tow it there. They found nothing wrong, I just stopped using cruise though I've had a couple of other shops check it out with no problems noted. I did recently replace the TPS and may try it out again.
1 - 13 of 13 Posts
