I was cleaning the IAC then I got called away for a senior meeting (finally graduating) and I left the IAC on the table. My cousin ( always been curious with things) took the pintil out. I got home put it back in after cleaning the IAC And throttle body. It's running about 5 600 rpms on idle. I shouldn't be worried right?
It runs and yes the idle could be a little higher more like 750-800 rpms.
Run it and see what it does of the idle is smooth don't worry
It runs and yes the idle could be a little higher more like 750-800 rpms. Run it and see what it does of the idle is smooth don't worry
It has the slightest sputter but it had that before. I've been trying to locate what is causing the sputter for awhile now and haven't narrowed it done yet. I was hoping that fixed it but it's the same as before
