Hi guys,
I have a 4.0L in my 02 wrangler. I was wondering which sensor is the intake air temp. sensor? I cant seem to find any documentation as to which it is. I know its probably around the throttle body but there are about 3 different ones there. Any help is appreciated.
Thanks,
You mean the idle air controller? (IAC) >..<
Knows a couple things...
The IAT sensor is not mounted on the throttle body itself, it's screwed into the intake manifold. There shouldn't be more than that one sensor actually screwed into the intake manifold. It's the one with the electrical plug on top with two connector pins inside the connector.
