Hey all. I attempted to install a Pioneer AVH-4100NEX today along with a idatalink maestro rr and CH1 wire harness and ran into a power issue. More specifically, the lack thereof. I had the CH1 terminated per the instructions from idatalink, but when I plug in the harness to the Jeep, the green power light doesn't come on on the maestro and neither does the HU. So I took a volt meter to the vehicle harness and was able to figure out (maybe incorrectly) that the yellow wire on one end of the harness is the power, and the black one at the other end is the ground. And I got voltage when testing. But when I test at the plug that powers the Maestro, I don't get any voltage on the red connector pin. Then I pulled the connection from the red wire on the CH1 (power) to the red wire on the Pioneer harness and tested for voltage there. I got nothing there too.
So as far as I can tell, I think I have a faulty CH1 wire harness. Anyone got any other ideas as to what my problem could be?
I ended up putting my stock HU back in and it works fine, so I know there's no fuse issue or anything like that either. I'm stumpted
