Ok guys, spent most of the weekend on this and have narrowed it down to a hopeful result. 1993 2.5l 5sp, the axle bearings on my rearend are starting to howl. I ordered the bearings and seals for a 1993 only to discover that the axles are not held in by C clips. The tag was bolted on the diff but its rusted at the end. I snapped some pics of the numbers on the ring gear since the tag wasn't able to do anything for me. None of the numbers I've located on the rear end did anything for me. There was a stamping on the cover sealing surface of the housing that read Dana 210. Going by the cover bolt pattern I think it's dana 35. It's an open diff with 4.11 gearing. It also used a roll pin to hold the pinion shaft in place. There are no threads for a bolt so that leads me to believe it was supposed to be there.
