What's up everybody! I have a really bad idle, and in park I have it up to 1200 rpm and once I shift into drive it goes down to 800 or 900 but bounces up and down sometimes to even 400 or 500. I drives fine but if I come to a stop it will stall out:nonono: I have to have it so high or else it will stall out when I put it in gear. I also have a terrible miss:eek:
TAC sensor may be bad. If yours is equipped with pulse air system, it could be bad or a bad MAP sensor. If you can get a hold of a repair or service manual, they will lay out how to check these parts.
Sounds like a vacuum leak. Mine was doing this and I ended up replacing the intake manifold gasket to solve the problem.
Yes original carter. I have a weber but need help putting it on. is there any really good ways to test for a vacuum leak? I don't want to keep replacing things if its not going to help
