This just started about 2 weeks ago. When i first start the engine, it idles around 1600 rmp for about 2 minutes then slowly drops to around 1100 rpm, after the temp gauge starts to move, it drops to around 700-800 rpm. Before it would idle at 1300-1400 for 5-10 seconds then drop to 1100 to warm up. After it drops to 700-800, if I push on the brake pedal it pushes the idle to 1100-1200. I am thinking there is a small hole in the brake booster diaphragm that opens when the brake pedal is depressed, however the brake pedal doesn't feel hard because of the loss of vaccum. Any suggestions?
check for vacuum leaks. clean IAC. change temp sensor. thats would be my first things to do. if that don't fix it then change TPS.
