How important is that small skinny metal part that sticks out beyond the ignition switch actuator pin. On the TJs the whole actuator pin assembly could be replaced for $45, on the 2007-2011 it is a whole housing for $145. I broke the soft metal extension of that pin. I searched for a replacement assembly but only the housing can be purchased so I took a chance and put it back together. The Jeep starts right up. So how important is that soft metal piece? Sorry for the really bad screenshot of someone's video. If this part proves terribly important I will drill out a little of the old one with a really small bit, get it to the right length, then just leave the bit in place as a replacement pin.
4441839
This is what the old ones looked like:
4441841
and this is what the 2007s have available (total overkill):
4441842
To clarify, the only part I am missing is the thin dark metal extension. It broke off when trying to put the new Ignition Switch on last night.
Do I need it? Is it worth $150? Will the Jeep shut off while driving or some such other nonsense?
Hi Fishbourne - I've been looking for days, and you're the first person I've found with the same issue I've had. Made the exact same mistake. Were you able to get any additional information about how important the PIN was?
Any chance you have a part number, or better picture of the unit? Thinking I need to buy one just in case...
Thanks!
Rich
RETIRED MODERATOR
Thanks!
Rich
Yeah, I found out that it doesn't matter at all. Been running it since then without the stupid little soft-metal pin.
I had it crank longer than expected once but no other symptoms and it has been 4 months.
Don't worry about it. It doesn't seem to matter.
